wesmithjr100
Mar 15, 2021Guide
Frequent Connectivity Issues After Upgrading SXR80 + Satellites to 3.2.3.100 Firmware
This past Saturday, I upgraded my Orbi Pro Wifi6 environment (1 router + 2 satellites) to the 3.2.3.100 firmware release as it was supposed to fix an issue I had previously come across/had reported. ...
RaghuHR
Mar 15, 2021NETGEAR Expert
Hi wesmithjr100
Could you please send me the debug logs by accessing thru https://<IP address of router or satellite>/debug.htm
Click on start capture -> recreate the issue -> wait for few minutes before you save the debug logs. Send me the logs via PM ( upload into google drive or something similar) .
Thanks,
Raghu
wesmithjr100
Mar 15, 2021Guide
I'll go ahead and enable debug now on my router but it will probably be another few hours before a recurrence based on the pattern to date. I'll then save the debug after that and make available to you via PM
Bill
- wesmithjr100Mar 15, 2021Guide
Tried tagging RaghuHR in prior reply but wouldn't let me post with it
RaghuHR PM with more info just sent to you
