MvRNL's avatar
MvRNL
MS60 satellites wont connect wireless after firmware upgrade.
Hi all,
after the latest update (1.1.6.122) My 2 satalites where burning amber and wasnt possible to see them anymore in the app or in the browser. after an factory reset i wasnt able to see the satellite at al after a while the satellite came back as "Netgear_setup" wifi point. i was able to connect to it with an cable and put the ip adres in the Macbook of the device to 192.168.1.250 and was able to reach it and downgrade the firmware to 1.0.6.102. now im able to connect it to the MR60 cabled but it is not possible to get it working wireless.
does anybody know an sollution for this problem?
