MvRNL
Jan 07, 2022Aspirant
MS60 satellites wont connect wireless after firmware upgrade.
Hi all, after the latest update (1.1.6.122) My 2 satalites where burning amber and wasnt possible to see them anymore in the app or in the browser. after an factory reset i wasnt able to see the ...
- Jan 07, 2022
I recommend if you see a FW update, ether use the MR and MS web pages to update or manually update the MS and MR using FW files.
There is a more recent version of FW as well:
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
MvRNL
thanks furrye38 for your reply.
it was updated true the nighthawk app.
after some searching on this forum i decided to factory default the router again and start installing from zero. problem is now solved.
it is now running on firmware 1.0.6.102. not sure to upgrade to what during the app is the newest firmware (1.0.6.116) cuase i readed that can also give some problems....
Jan 07, 2022Guru - Experienced User
Enjoy. 📡
- LopezFam6Jan 10, 2022Aspirant
Satellites (2) both have red lights. Satellites show that latest FW (122) is uploaded, but Router shows FW (166) and no updates available. Both satellites show offline.
- MvRNLJan 11, 2022AspirantHi lopez,
Same was here. You can manually update the router to 122 firmware. But I downgraded everything to 116 I believe. And then everything seems okay again after an factory reset and new instal from router. - MvRNLJan 11, 2022AspirantJust got an reply from Netgear NL. You can manually update the router. https://www.downloads.netgear.com/files/GDC/MK62/MR60-V1.1.6.122_2.0.58.zip
After that you have to press the reset button for 30 sec. Then you have to set it ip as new.- FURRYe38Jan 19, 2022Guru - Experienced User
Same version as already posted in this thread and top of the forum.
