wesmithjr100
Mar 15, 2021Guide
Frequent Connectivity Issues After Upgrading SXR80 + Satellites to 3.2.3.100 Firmware
This past Saturday, I upgraded my Orbi Pro Wifi6 environment (1 router + 2 satellites) to the 3.2.3.100 firmware release as it was supposed to fix an issue I had previously come across/had reported. ...
algonline
Mar 20, 2021Initiate
I don't think this is due to the 3.2.3.100 firmware. I started having this same problem on the 14th after the time change. Upgraded to 3.2.3.100 and was still running into this problem every few hours. I disabled Automatically adjust for daylight savings time and have not had an issue since. See this thread. https://www.reddit.com/r/orbi/comments/m5l3vk/orbi_dropping_dns/
- wesmithjr100Mar 21, 2021Guide
Agreed - at the time I created the post the firmware upgrade was the most recent / significant action I had taken so I initially linked the two together. Based on conversations with Netgear support and other postings here and elsewhere, it's clear it was a bug related to DST. Netgear suggested toggling the traffic counter setting to reset at 1 AM vs default 00:00 and that seems to have worked for me as an interim workaround at least
