django2020
Jan 28, 2023Aspirant
Frustrated after V4.2.3.102 update
Router: SXR80 Satellite: SXS80 Firmware: v4.2.3.102 Problems: 1. Android play store is no longer able to download or update apps. Works when on Cellular or Work WiFi. 2. YouTube takes foreve...
Jan 29, 2023Guru - Experienced User
Did it work better with the firmware downgraded?
Did you try a factory reset?
What modem/gateway is it connected to?
django2020
Jan 29, 2023Aspirant
Nope hasn't worked after I have downgraded. Will try a factory reset next weekend. Will keep you guys posted.
