JBQuinnforRCRC's avatar
Dec 17, 2023
Guest Network Signal Weak SXR30 and WAX620
We have an SXR30 ORBI router hardwired to five WAX620 access points.  Guest network is enabled along with three other SSID's.  The Guest network signal is significantly weaker than the other SSID's, and noticeably from one AP.   In some cases, it does not appear as on option.  It also drops a good deal.
Does anyone know how to bring the Guest network signal up to the strength of the other SSID's?  Why would one AP be different than the others?
1 Reply
  • schumaku's avatar
    schumaku
    Hard to imagine. All virtual SSIDs are coming from the same radio.
ProSupport for Business
