JBQuinnforRCRC's avatar
Nov 13, 2023
Guest Network
Our Guest lnetwork disconnects about every two weeks.  I have the reboot the router which then forces everyone through the Terms and Conditions signature.  Only the Guest network disconnects.  Why is this happening and how does it get fixed?
1 Reply
  • schumaku's avatar
    schumaku
    Can just guess what Netgear's design idea for a guest network is: It's simply not intended for continuous 24*7 operations without re-authentication on the portal and in no aspect yet another SSID and generic network. Rebooting the router should not be required however to allow the clients to associate again.
    Because of the R6700AX isn't a Orbi Pro system, I'll request a moderator moving your post to the generic Nighthawk router community section -> Nighthawk With WiFi 6 (AX) And WiFi 6E (AXE) Routers
ProSupport for Business
