shejialun
Jul 30, 2023Aspirant
How do I change my WiFi region to USA?
I purchased an SXK80 product from Amazon USA, the default WiFi region was USA when I got it, I have done firmware recovery and region modification through NMRP Server software (previously used in R70...
BasuKhodanapur
Aug 01, 2023Apprentice
Hi shejialun ,
Please select NA if you want to recover to the USA area. I think it will resolve your issue. Let me know .
Thanks,
Basavaraj
shejialun
Aug 01, 2023Aspirant
Hello Basavaraj,
I have two questions:
Is the US region code being canceled?
Does NA mean North America, the same wireless standard as the US? thanks
- BasuKhodanapurAug 01, 2023Apprentice
Hi shejialun ,
I don't think US region is cancelled.
two things:
1. NA mean North America, the same wireless standard as the US.
2. What i feel is if you configure North America, NA region has drop down list of US as well. I'm not 100% sure about it.
Thanks,
Basavaraj
Hi shejialun ,
Please DM me your details like Serial No, Firmware version and customer details
if insight managed, insight account username.
Thanks,
Basavaraj
- shejialunAug 01, 2023AspirantHello BasuKhodanapur
DM means direct message to you? right?
I've messaged you the product details, please check, thank you.
I have tested the configuration to NA but the region selection becomes grayed out and unselectable, which is the same as when my product arrived with the wireless region being USA.- schumakuAug 02, 2023Guru - Experienced User
shejialun wrote:
I have tested the configuration to NA but the region selection becomes grayed out and unselectable, which is the same as when my product arrived with the wireless region being USA.This is what the FCC regulations mandate for: No user access to alternate regulatory areas. What do you expect after all this experiments?
