shejialun
Jul 30, 2023Aspirant
How do I change my WiFi region to USA?
I purchased an SXK80 product from Amazon USA, the default WiFi region was USA when I got it, I have done firmware recovery and region modification through NMRP Server software (previously used in R70...
shejialun
Aug 01, 2023Aspirant
Hello BasuKhodanapur
I have tested the configuration to NA but the region selection becomes grayed out and unselectable, which is the same as when my product arrived with the wireless region being USA.
schumaku
Aug 02, 2023Guru - Experienced User
This is what the FCC regulations mandate for: No user access to alternate regulatory areas. What do you expect after all this experiments?
- shejialunAug 02, 2023AspirantAs I said before, I'm trying to change back to the US region now, but I can't find the US region, so I have to change back to the NA region!
So I would like to confirm that this device has a US region option?
Is the NA region equal to the US region for wireless power and signal?
I actually have another older unit model R7000 which has always been able to select the US region, but my newer SXK80 can't find the US region anymore, which makes me I'm confused!
