Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
schumaku
Feb 12, 2024Guru - Experienced User
Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 192.168.1.3.
However I can access and login to the following: ...
Please be a little bit more verbose. What happens, why do you think you can't login? Any messages, any screenshots, ....?
- MstrbigFeb 12, 2024Master
Hmmm… can't reach this page
It looks like the webpage at https://192.168.1.1/ might be having issues, or it may have moved permanently to a new web address.
- schumakuFeb 12, 2024Guru - Experienced User
Interesting. Has the latest hack somebody tried on the consumer routers with some wannabee-sso-like-code in qa-quality made it over to the Orbi Pro? What I have in mind is this wonderful *****. Does this look familiar what might go on under the hood there?
Wait - do you have https enabled on your Orbi Pro SXK80 system?
Or have probably the Facebook Wi-Fi portal for the guest WiFi network enabled and active? Wireless > Guest Portal (Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual, p.109 ff.)
The special 192.168.1.1 URLs you listed before are plain http only of course?
No, but I'll try to access and double check.
- quagmire1Feb 13, 2024Luminary
Is this the actual error message?
ERR_SSL_KEY_USAGE_INCOMPATIBLE
If so, this is a known issue. There are several threads here discussing it. Workaround is to use Firefox. We're waiting for Netgear to fix this - it's ultimately on them.
- DavidGoFeb 14, 2024NETGEAR Expert
Hi all,
The issue is confirmed and we now have a patch firmware to fix it. After installing the patch firmware a factory reset is required.
If anyone would like to install the patch firmware please send me a PM.
Thanks
DavidGo
