Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
schumaku
Feb 12, 2024Guru - Experienced User
Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 192.168.1.3.
However I can access and login to the following: ...
Please be a little bit more verbose. What happens, why do you think you can't login? Any messages, any screenshots, ....?
Mstrbig
Feb 12, 2024Master
Hmmm… can't reach this page
It looks like the webpage at https://192.168.1.1/ might be having issues, or it may have moved permanently to a new web address.
- schumakuFeb 12, 2024Guru - Experienced User
Interesting. Has the latest hack somebody tried on the consumer routers with some wannabee-sso-like-code in qa-quality made it over to the Orbi Pro? What I have in mind is this wonderful *****. Does this look familiar what might go on under the hood there?
Wait - do you have https enabled on your Orbi Pro SXK80 system?
Or have probably the Facebook Wi-Fi portal for the guest WiFi network enabled and active? Wireless > Guest Portal (Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual, p.109 ff.)
The special 192.168.1.1 URLs you listed before are plain http only of course?
- MstrbigFeb 12, 2024Master
No, but I'll try to access and double check.
Ref. the Facebook WiFi guest portal https://kb.netgear.com/000055556/How-do-I-set-up-and-enable-Facebook-Wi-Fi-on-my-wireless-access-point ... Meta is winding down this service, or has finally done it now. So this feature became obsolete from what I understand. plemans do you have some insights for a non-Orbi Pro owner like me? Have these controls be removed, or does everthing remain in place (without practical usage), and levaing any kind of side effects open?
- quagmire1Feb 13, 2024Luminary
Is this the actual error message?
ERR_SSL_KEY_USAGE_INCOMPATIBLE
If so, this is a known issue. There are several threads here discussing it. Workaround is to use Firefox. We're waiting for Netgear to fix this - it's ultimately on them.
- DavidGoFeb 14, 2024NETGEAR Expert
Hi all,
The issue is confirmed and we now have a patch firmware to fix it. After installing the patch firmware a factory reset is required.
If anyone would like to install the patch firmware please send me a PM.
Thanks
DavidGo
