Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
schumaku
Feb 12, 2024Guru - Experienced User
Wait - do you have https enabled on your Orbi Pro SXK80 system?
Or have probably the Facebook Wi-Fi portal for the guest WiFi network enabled and active? Wireless > Guest Portal (Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual, p.109 ff.)
The special 192.168.1.1 URLs you listed before are plain http only of course?
Mstrbig
Feb 12, 2024Master
No, but I'll try to access and double check.
- schumakuFeb 12, 2024Guru - Experienced User
Ref. the Facebook WiFi guest portal https://kb.netgear.com/000055556/How-do-I-set-up-and-enable-Facebook-Wi-Fi-on-my-wireless-access-point ... Meta is winding down this service, or has finally done it now. So this feature became obsolete from what I understand. plemans do you have some insights for a non-Orbi Pro owner like me? Have these controls be removed, or does everthing remain in place (without practical usage), and levaing any kind of side effects open?
- plemansFeb 13, 2024Guru - Experienced User
schumaku I never used the facebook options as I avoid social media like the plague 🙂
Mstrbig I know it sounds stupid, but did you end up on a different IP address? did you check the gateway to confirm its at 192.168.1.1?
- MstrbigFeb 13, 2024Master
No, same IP address, pinging and tracert fine. Also the router and satellites are up and running perfect. Just cannot log in because of a certificate anomaly. And I can't find a work around.
The really weird thing is I can access no problem to 192.168.1.1/debug.htm
