Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
Feb 13, 2024Guru - Experienced User
schumaku I never used the facebook options as I avoid social media like the plague 🙂
Mstrbig I know it sounds stupid, but did you end up on a different IP address? did you check the gateway to confirm its at 192.168.1.1?
Mstrbig
Feb 13, 2024Master
No, same IP address, pinging and tracert fine. Also the router and satellites are up and running perfect. Just cannot log in because of a certificate anomaly. And I can't find a work around.
The really weird thing is I can access no problem to 192.168.1.1/debug.htm
