Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
Mstrbig
Feb 12, 2024Master
Hmmm… can't reach this page
It looks like the webpage at https://192.168.1.1/ might be having issues, or it may have moved permanently to a new web address.
quagmire1
Feb 13, 2024Luminary
Is this the actual error message?
ERR_SSL_KEY_USAGE_INCOMPATIBLE
If so, this is a known issue. There are several threads here discussing it. Workaround is to use Firefox. We're waiting for Netgear to fix this - it's ultimately on them.
- DavidGoFeb 14, 2024NETGEAR Expert
Hi all,
The issue is confirmed and we now have a patch firmware to fix it. After installing the patch firmware a factory reset is required.
If anyone would like to install the patch firmware please send me a PM.
Thanks
DavidGo
- schumakuFeb 14, 2024Guru - Experienced User
Hello DavidGo
Lost as before.... what was relly fixed now?
We're supposed being able to login to the Web UI as before?
A new self.signed certificate deployed so the ERR_SSL_KEY_USAGE_INCOMPATIBLE error does no longer appear?
Can a factory reset, thus new installed SXKn0 be added again to Insight, so the settings are back?
Thank you
-Kurt
- DavidGoFeb 15, 2024NETGEAR Expert
Hi schumaku
In the patch firmware it is just fixing the issue where the SXK80 is not allowing login to the local admin page, but everything else is working as normal.
After installing the patch firmware and doing the factory reset the ERR_SSL_KEY_USAGE_INCOMPATIBLE error no longer appears.
If the device is added in Insight, it should come back online in Insight and sync the config once Internet access is restored to the SXR80.
Thanks
DavidGo
- MJDSFeb 15, 2024Aspirant
Hello DavidGo,
I have the same problem with my router.
Is there a new firmware update for my router.
At this moment there isn't one.
