Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
DavidGo
Feb 15, 2024NETGEAR Expert
Hi schumaku
In the patch firmware it is just fixing the issue where the SXK80 is not allowing login to the local admin page, but everything else is working as normal.
After installing the patch firmware and doing the factory reset the ERR_SSL_KEY_USAGE_INCOMPATIBLE error no longer appears.
If the device is added in Insight, it should come back online in Insight and sync the config once Internet access is restored to the SXR80.
Thanks
DavidGo
Mstrbig
Feb 15, 2024Master
The patch did not work for me in the latest version of Edge in Windows 11.
I was able to access my CP with Firefox and install the patch. I confirmed the router and both satellites installed the patch. Unfortunately, there was No change in Edge after factory reset.
