Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
Techdeskxy
Feb 15, 2024Aspirant
Did you push the firmware update through the app or the web portal?
Mstrbig
Feb 15, 2024Master
Web Portal
But! I have an update. After attempting and failing following the instructions, I went back to Firefox, accessed my Orbi router and backed up and erased the routers settings bringing it back to factory settings. Then I restored it from my backup. I did not reboot or anything. I went to the latest update of Edge and now I can access the router at he normal ip 192.168.1.1 with no error. I don't know why the factory reset did not work, but for me the above method completed the fix.
