twinklestar711
Jan 14, 2024Follower
I can't log into 192.168.1.1 and I have orbi pro SXR80
I need your help ASAP please. My internet was working fine and this morning it stopped. I called my internet provider and they detected it's Netgear Orbi issues. I'm still on hold with netgear fo...
schumaku
Jan 14, 2024Guru - Experienced User
It's a connection you establish on your very own network, so choose Advanced and then accept the security exception. No need to call Netgear - don't become a slave to the always raising expectations. Much more infrastructure and effort would be required to get a valid certificate - and definitively none for a generic or universal DNS name. Certificate policies do no longer allow to distribute private keys at will of the industry or us users.
Yes, I'm yet another user: So I have to point you to the fine documentation - Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual on p.33 "What to do if you get a browser security warning".
- squared80Feb 06, 2024Aspirant
That did not work for me.
- WisconsinBenFeb 07, 2024Aspirant
Yeah, the "proceed" option is before the ERR_SSL_KEY_USAGE_INCOMPATIBLE error message.
- schumakuFeb 07, 2024Guru - Experienced User
Say thank you browser makers for pushing forward faster than the industry can follow 8-/
Check this in case you are using Google Chrome: https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Chrome-Certificate/m-p/2352915/highlight/true#M6584
Doesn't work on Chromebooks.
