twinklestar711
Jan 14, 2024Follower
I can't log into 192.168.1.1 and I have orbi pro SXR80
I need your help ASAP please. My internet was working fine and this morning it stopped. I called my internet provider and they detected it's Netgear Orbi issues. I'm still on hold with netgear fo...
WisconsinBen
Feb 07, 2024Aspirant
Yeah, the "proceed" option is before the ERR_SSL_KEY_USAGE_INCOMPATIBLE error message.
schumaku
Feb 07, 2024Guru - Experienced User
Say thank you browser makers for pushing forward faster than the industry can follow 8-/
Check this in case you are using Google Chrome: https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Chrome-Certificate/m-p/2352915/highlight/true#M6584
- WisconsinBenFeb 07, 2024Aspirant
Doesn't work on Chromebooks.
- schumakuFeb 07, 2024Guru - Experienced User
Nothing I can do for you except of pushing Netgear again to create and distribute new self-signed certificates ... as I wrote in the post referred above. Not deep enough in the Chromebook world anymore, suspect a similar workaround might be possible. Say thank you to Google for pushing forward much to fast ....
You might have to go with the Chrome Beta and take controls of the extperimental features https://support.google.com/chrome/answer/10612145?hl=en
