mareksuski1
Oct 21, 2022Follower
If i use only SXR80 (router without a satellite) is 2nd 5Ghz used?
Hi, I am planning to buy SXR80 (router without satellites) and wonder if then the 3rd radio (2nd for 5GHz) is off as there is no satellites connected? Or maybe it is used to connected more clients ...
Oct 21, 2022Guru - Experienced User
No. Its not turned off and its not user accessible. its strictly for the backhaul and isn't user manageable. (sadly)
Dirk_Dutch
Jan 03, 2023Initiate
I connected the SXR to SXS by CAT6 cable to have a wired backhaul. The backhaul 5GHz-2 is now available for the devices (channel 108). Is this wrong? Available are now: Channel 1 - 2.4GHz & Channel 36 - 5Ghz & Channel 108 - 5Ghz, for all devices.
- plemansJan 03, 2023Guru - Experienced User
Unless something has changed recently ( BruceGuo ) even using a wired backhaul shouldn't allow all 3 bands to be user accessible. Netgear has been pretty firm on not allowing the wireless backhaul to be used even when using a wired backhaul. Again, something could have changed and as I don't have a triband Pro system (just dual band), I can't attest to how the most recent version is functioning with a wired backhaul.
- Dirk_DutchJan 04, 2023Initiate
I have added a picture for clarity. This is how it looks. Is it not possible, or not allowed, to use the 'Backhaul 5Ghz'. I can't turn it off.
- plemansJan 04, 2023Guru - Experienced User
sure looks likes its usable. Users have been asking for that for years so not sure if its something new or a fluke.
