mcnahum
Aug 29, 2021Apprentice
Is the SXR80 / SXS80 can really work in AP mode?
I decided to upgrade my network with a UDM PRO My DHCP and DNS are managed by a Pi-hole If I’m trying to setup the SXR80 as AP … it’s not reachable at all after a reboot. I tried with a fixed I...
JohnC_V
Aug 30, 2021NETGEAR Employee Retired
Hi mcnahum,
Welcome to our community! :)
It seems that you are having issues setting up the Orbi Pro to AP mode. May you be able to provide us some screenshots in order for us to check it?
John
NETGEAR Community Team
RaghuHR
Sep 02, 2021NETGEAR Expert
mcnahum It looks like there are known issues with Pi-hole wrt DHCP. Please check
Here are some DHCP issues which is reported in po-hole setup,
Method 1: Generate a debug token via the Web interface Log in to your Pi-hole’s Web interface Navigate to Tools > Generate debug log Click the Generate debug log button Send us the debug token Method 2: Use the command line to generate a debug token Login into your Pi-hole’s command line Enter pihole -d Provide us with the debug token that is generated after the debug script completes ...
discourse.pi-hole.net
