Bnjmn22
Sep 20, 2022Aspirant
Is VLAN Tagging supported yet?
Hi, My ISP CenturyLink requires VLAN tagging for incoming packets. Does the SXK80 / Orbi Pro support it yet, or do I have to install a beta firmware still?
Marc_V
Sep 20, 2022NETGEAR Employee Retired
Is this for IPTV? SXK80 supports VLAN tag/bridge settings if your ISP requires you to use VLAN tag. Here is the manual for the SXK80, you may check on page 87. You dont need to install a BETA Firmware.
HTH
Bnjmn22
No, this is a custom VLAN tag 201.
My original thread is here: https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Need-help-with-Vlan-tagging-for-sxs80-wired-backhaul/td-p/2200282
There was no solution except for a beta firmware at the time. Is that still the case? If so, what is the latest beta?
- Marc_VSep 20, 2022NETGEAR Employee Retired
Are you on the latest FW? The fix should have been applied to ver 4.2.1.120
Do you have an existing case about this issue? I will check on it if you have one, you can send me a PM regarding this info.
many thanks!
- Bnjmn22Sep 20, 2022Aspirant
Yes, I just upgraded to V4.2.2.130. Where do I set all external / incoming traffic to VLAN tag 201?
Thank you.
- capinSep 29, 2022Tutor
Under Advanced -> Advanced Setup -> VLAN / Bridge Settings, I created a vlan named internet with a VLAN ID of 201 and network and client isolation turned on.
I assigned this vlan profile to my WAN port and it worked with CenturyLink fiber.
Also under internet setup I set the ISP to PPPoE and entered the login and password with connection mode always on.
This is firmware version V4.2.2.130 on SXR80 hardware.
