dir's avatar
dir
Apprentice
Mar 02, 2020
keeps forgetting / prompting for password
I recently installed Insight on my phone.  Now I seem to have problems if I try to log into the SRR60 web portal directly.  It rejects my password then goes into password recovery (enter serial #, et...
  • Leia's avatar
    Mar 02, 2020
    Hi dir,
    Since you added your SRR60 onto Insight, Insight would manage all devices' admin passwords by locations that you set. I guess you set different passwords on Insight and SRR60 admin GUI.
    So you can change the password on Insight app:
    1. After login, click "Locations" button, then "Location Configuration";
    2. Change "Device Admin Password" and save.
    Thanks,
    -Leia
ProSupport for Business
