TheGrumpyGent
Apr 21, 2022Tutor
Local Login if Managing Orbi in Insight?
If I register my Orbi Pro with Insight, it changes the credentials (and settings!) locally on the router. How do you login to the local admin screen, as none of the credentials I have appeared to wo...
- Apr 21, 2022
Hi TheGrumpyGent,
It should be the Device Admin Password which is located on Locations > Location Configuration.
For your reference, kindly check this KB article.
JeraldM
NETGEAR Community Team
JeraldM
Apr 21, 2022NETGEAR Employee Retired
Hi TheGrumpyGent,
JeraldM
- TheGrumpyGentApr 22, 2022Tutor
Thank you! Not sure how I missed that (but I did!)
