TheGrumpyGent
Apr 21, 2022Tutor
Local Login if Managing Orbi in Insight?
If I register my Orbi Pro with Insight, it changes the credentials (and settings!) locally on the router. How do you login to the local admin screen, as none of the credentials I have appeared to wo...
- Apr 21, 2022
Hi TheGrumpyGent,
It should be the Device Admin Password which is located on Locations > Location Configuration.
For your reference, kindly check this KB article.
JeraldM
NETGEAR Community Team
JeraldM
Apr 21, 2022NETGEAR Employee Retired
Hi TheGrumpyGent,
JeraldM
TheGrumpyGent
Apr 22, 2022Tutor
Thank you! Not sure how I missed that (but I did!)
