JoeJoeJoeJoe
Dec 24, 2021Tutor
Moving from Orbi RBR50 or Orbi PRO SXR80 - CenturyLink (fiber) VLAN setup question - direct to ONT
I currently have a Orbi RBR50 working with CenturyLink fiber. Requires PPPoE login and VLAN 201 tagging. My Orbi is direct connected to the CenturyLink ONT via Ethernet WAN port. Questions on s...
racoon
Jan 20, 2022Aspirant
I'm having the same issue, plus the internet connection is limited at 130 Mbps instead of 1000mbps
- FURRYe38Jan 21, 2022Guru - Experienced User
Please make a new post in the appropriate forum. If you have Orbi Pro, please post there.
racoon wrote:
I'm having the same issue, plus the internet connection is limited at 130 Mbps instead of 1000mbps- racoonJan 24, 2022Aspirant
i cant post on that community
- FURRYe38Jan 24, 2022Guru - Experienced User
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
