mrymk's avatar
mrymk
Tutor
Mar 25, 2021
Orbi RBR850 with Centurylink Fiber
Hello Everyone,
I have a question. I am changing my Dads router to the Orbi RBR850 with Centrylink. Previous the router was at my house where I had no problems, only diff is that I have Xfinity.
I have tried to configure the PPOE setting with the correct user name and password however no luck. I tells me that it can non find the internet.
There is no Modem since its fiber so eveything coming into the house in COAX with CAT 5 cabeling coming into a switch at the juncion box and then lighting up the ports in the house.
Help would be appreciated.
Mike
  • Thanks for letting us know. Please mark your thead and solved so others will know.
    Enjoy. :smileywink:
  • FURRYe38's avatar
    I would also ensure your using good quality LAN cables. CAT6 is recommended.
    What is the Mfr and model# of the ONT the RBR is connected too?
    Does using DHCP instead of PPPoE result in any difference?
    Try powering OFF both RBR and ONT for 30 seconds then back ON.
    I would contact the ISP and ask for help and information on this. Possible that PPPOE may not be needed.
  • I have the same setup, and I couldn't connect the Orbi router directly to the ONT (the Optical Network Terminal, the box the fiber connection goes to). You need something in between the ONT and the Orbi to handle VLAN tagging.That could be a modem, but it can also just be a network switch. Just make sure you get one that handles VLAN tagging -- I bought a ProSafe switch and that did the trick.
    Here's an article on it: https://www.dslreports.com/forum/r31043915-How-to-almost-use-any-router-with-CenturyLink-s-1-Gig-Internet
  • FURRYe38's avatar
    Any progress on this?
    mrymk wrote:
    Hello Everyone,
    Mike
    • mrymk's avatar
      mrymk
      Tutor
      Here’s what I did tonight to resolve this. I found out that CenturyLink by default tags their internet traffic with 201. I then logged into the admin console while it was being configured and performed the following.
      Call Centurylink for your pppoe username and password and vlan number which is (201)
      Have laptop and ethernet wire
      Log on to orbilogin.net
      On Basic tab
      Make sure you have to the most updated firmware on your router and satellite
      Once you determine your software is up to date
      Enter your internet service provider pppoe and password
      Go into your Advanced tab
      Advance setting change to vlan to 201
      Follow orbi instruction on set up
      Your internet should connect
      • FURRYe38's avatar
        Enjoy. :smileywink:
