Cyrilblanc
Aug 25, 2022Aspirant
Multiple WIFI network on an ORBI
Hello Orange keeps changing the name of my two WIFI network đ« so my Alexa is down each time. I have about 80 devices so there is no question I have to change the setting of those devices each time...
- Sep 01, 2022
Hello
I have found that you can have 3 x WIFI network that have 2 x SSID, one for 2.4 and one for 5 ghz
Netgear send a note today about 6 ghz
CrimpOn
Aug 25, 2022Guru - Experienced User
It would help to know the components of this network:
- The Internet Service Provider is Orange, correct?
- What equipment has Orange provided?
- This Orange equipment broadcasts WiFi channels, and Orange changes the WiFi name (SSID) of these channels?
- There is a Netgear Orbi system connected to the Orange equipment?
(specific model numbers would help) - What 'mode' is the Orbi system set to? (router or access point?)
- CyrilblancAug 26, 2022Aspirant
Hello
My replies are Bold CAPS.
- The Internet Service Provider is Orange, correct? YES
- What equipment has Orange provided? ROUTER ON FIBER
- This Orange equipment broadcasts WiFi channels, and Orange changes the WiFi name (SSID) of these channels? YES
- There is a Netgear Orbi system connected to the Orange equipment? YES ORBI PRO WIFI 6
(specific model numbers would help) - What 'mode' is the Orbi system set to? (router or access point?) ROUTER
Hope this help
Thanks
Cyril
