littlebear
Aug 05, 2015Tutor
Multiple wifi routers one network
my home broadband is accessed via a phone line.
on one access point upstairs I have installed a D3600 but the signal is too weak to access downstairs and an extender is not helping.
is it possible to connect a Nighthawk to another downstairs phone line and create one network, with one name, and one password?
thanks
R
So you are willing to have one extra subsription to your ISP? Then do it and see how it goes coverage wise.
- DaenerysLuminary
Yes. Set the 2nd unit to AP mode.
- Babylon5NETGEAR Employee Retired
Littlebear, your post appears a little confused. Your D3600 is a DSL modem/router and it’s the modem function of the D3600 that enables it to connect to your phone line and onwards to your ISP. I’m not DSL expert, but I don’t think you can simply add a second DSL modem/router to another phone connection point in the house. What you can do, which is what I think Daenerys is suggesting, is to connect the other router to the D3600 via Ethernet cable, and configure the second router as an Access Point. Just out of interest though, do you already have that second Nighthawk router that you refer to?
Hi Andy,
thanks for your response.
yes I do already have the Nighthawk. I'm currently attempting to set it up first as the primary router with the D3600 disconnected, before seeing if both will connect.
Having trouble getting it to recognise the ISP log-in, working in that at the moment
What is the model type of the other Nighthawk? If it’s a Dxxxx then it can connect to your phoneline, if it’s an Rxxxx then it does not contain the necessary DSL modem to be able to connect to the phoneline. Whatever the case, I suggest that you really only want to create one network where you have one primary router/gateway connected to the phoneline, and maybe a secondary router configured as an access point (since you already have a second router).
