Cyrilblanc
Aug 25, 2022Aspirant
Multiple WIFI network on an ORBI
Hello Orange keeps changing the name of my two WIFI network đ« so my Alexa is down each time. I have about 80 devices so there is no question I have to change the setting of those devices each time...
- Sep 01, 2022
Hello
I have found that you can have 3 x WIFI network that have 2 x SSID, one for 2.4 and one for 5 ghz
Netgear send a note today about 6 ghz
Aug 26, 2022Guru - Experienced User
One system that does support separate SSID name is the Nighthawk MK series MESH systems.
Cyrilblanc
Sep 01, 2022Aspirant
Hello
