ynghill
Jan 03, 2022Tutor
NAT loopback does not work on lan connection but only on wifi
Hi, I have a new system with router SXR80 and 3 satellite SXS80. With a computer wired LAN to the router where my web server and sql server are also connected, my ddns address from NO-IP does not w...
schumaku
Jan 03, 2022Guru - Experienced User
Reads like NAT loopback from devices connected or associated with a satellite does not loop back to the router connected device.. BruceGuo please advise - think we talked about this before.
- ynghillJan 04, 2022Tutor
Hello
If I understand you correctly, this is my first post.
Trying to clarify my problem.
Both lan (cable) and wifi devices connected to a satellite OR the router can not connectto the server that is lan (cable) connected to the router.
For wifi connected devices directly on the router works.
If the satellite uses wifi for communication to the router, it works..I have the impression that something is wrong with the firmware.
Yngve.
