yazun
Sep 16, 2021Aspirant
NAT loopback _not working_ on SXS80 Satellite.
Hello,
Contrary to some information from this forum we cannot get loopback NAT working on SXS80.
It does work while connected to the main router (SXR80) but it is ridiculous one has to be connected to a speific point of the mesh system to get such basic functionality working.
Has anynody has any hints how to enable this for the sattelite?
We can get it working for few seconds by changing kernel params, but the satellite reboots then after few seconds as a security measure (sic!).
Hope soembody can help, support has ignored the question so far.
on satellite: cat /proc/sys/net/bridge/bridge-nf-call-iptables 1 root@SXS80:~# sysctl -p kernel.panic = 3 net.ipv4.conf.default.arp_ignore = 1 net.ipv4.conf.all.arp_ignore = 1 net.ipv4.ip_forward = 1 net.ipv4.ip_option_rr_ssrr_lsrr_pass_through = 1 net.ipv4.ipfrag_overlap_drop = 1 net.ipv4.icmp_echo_ignore_broadcasts = 1 net.ipv4.icmp_ignore_bogus_error_responses = 1 net.ipv4.igmp_max_memberships = 100 net.ipv4.tcp_ecn = 0 net.ipv4.tcp_fin_timeout = 30 net.ipv4.tcp_keepalive_time = 120 net.ipv4.tcp_syncookies = 1 net.ipv4.tcp_timestamps = 1 net.ipv4.tcp_sack = 1 net.ipv4.tcp_dsack = 1 net.dni.dod_skip_control_packet = 1 net.ipv6.conf.default.forwarding = 1 net.ipv6.conf.all.forwarding = 1 net.netfilter.nf_conntrack_acct = 1 net.netfilter.nf_conntrack_checksum = 0 net.netfilter.nf_conntrack_max = 65536 net.netfilter.nf_conntrack_tcp_timeout_established = 7440 net.netfilter.nf_conntrack_tcp_timeout_syn_sent = 60 net.netfilter.nf_conntrack_tcp_timeout_time_wait = 60 net.netfilter.nf_conntrack_udp_timeout = 300 net.netfilter.nf_conntrack_udp_timeout_stream = 300 net.netfilter.nf_conntrack_icmp_timeout = 60 net.bridge.bridge-nf-call-arptables = 0 net.bridge.bridge-nf-call-ip6tables = 0 net.bridge.bridge-nf-call-iptables = 0 vm.min_free_kbytes = 12288 --- config set reset_satelliteconfigs_forced=0 config commit # NAT loopback works for few seconds then reboots after echo 0 > /proc/sys/net/bridge/bridge-nf-call-iptables
would appreciate any hints.
think it's not serious to have such a problem with any hardware at this price point.
- yazunAspirant
For the record, statement from the thread below is only partially true - it does not apply to the satellite!
.Does-OrbiPro-Wifi-6-SXK80-support-nat-loopback/m-p/1971577#M2345
