Bnjmn22
Feb 26, 2022Aspirant
Need help with Vlan tagging for sxs80 wired backhaul
Hi, I have Century Link fiber. My Orbi RBK853 worked fine with wan Vlan tagging for both the router and satellite. However, I had to switch to the Orbi Pro system for the multiple VLAN ssid func...
Bnjmn22
Update,
I installed the new 4.0.0.118 firmware and I see the Bridge/VLAN tag I was using is gone. Now, there is an IPTV one I set to 201, and then I set the WAN back to 1/default and it does not connect to internet. However, when I set WAN to 201, a custom ID I created, it works but the satellite is not working again.
Also no lan ports are connecting to the internet either.
Bnjmn22
Ok, so now I have the second port set to the IPTV VLAN (set to 201). This port, on the router, is hardwired to my satellite (port 1) for backhaul. Its working again similarly to how Bridge/VLAN was working.
However, this is because it is now wirelessly backhauling. I have confirmed this by unplugging the satellite. Also wired LAN ports on the router cannot access internet. It seems like VLAN tagging can only be set to one port at one time?
Can someone provide clarity? Is having an external switch like the GS105Ev2 set to 201 tagging, the only real solution?
I thought the beta firmware would have a fix :) my family is starting to hate me working non stop on the weekend on this.
