Bnjmn22
Feb 26, 2022Aspirant
Need help with Vlan tagging for sxs80 wired backhaul
Hi, I have Century Link fiber. My Orbi RBK853 worked fine with wan Vlan tagging for both the router and satellite. However, I had to switch to the Orbi Pro system for the multiple VLAN ssid func...
DaneA
Feb 28, 2022NETGEAR Employee Retired
Welcome to the community! :)
I found the exact same problem someone else was having. https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Help-on-configuring-Wired-ports-for-Internet-access-via-Employee/m-p/2177374
I'm also on CenturyLink that requires a 201 tag VLAN, which is why my WAN is set to 201.
Is there no other solution but buying an extra switch?
What is the new beta firmware solution?
I have the new beta firmware installed.
Just found out that the community member, JoeJoeJoeJoe, from this thread was given a beta firmware by the higher tier of NETGEAR Support. It might be different from the beta firmware version you are referring to that you have uploaded to your SXK80.
I installed the new 4.0.0.118 firmware and I see the Bridge/VLAN tag I was using is gone.
Since you have already uploaded the official latest firmware version that was recently released, let us try to perform a factory reset on your SRK80 then reconfigure the settings from scratch and check if you will encounter the same problem.
DaneA
NETGEAR Community Team
Bnjmn22
Feb 28, 2022Aspirant
Yes, I did a factory reset and it is still not working, so maybe it is a different beta.
As an update to this thread, I bought an external netgear switch GS105Ev2 and I tagged the in-coming traffic on port 1/2 and connected port 1 to my CenturyLink fiber and port 2 to the SXR80 and that fixed the issue. It does require an extra physical hop/cost which is not ideal given the RBR8530does this inside the router itself.
- Bnjmn22Mar 06, 2022Aspirant
I recieved a message asking if I wanted the beta firmware to fix VLAN tagging. However the FROM email was do_not_reply@neatgear.com and no way to reply to JeraldM or DaneA.
I also recieved the beta agreement form but nowhere to sign or "Accept".
It does say "Thank you for accepting, someone will be in touch". Or something like that. So I assume its "accepted" by clicking on it.
Can someone please help as I would like to new beta firmware for VLAN tagging fix on WAN?
- FURRYe38Mar 06, 2022Guru - Experienced User
Try sending DaneA or JeraldM a PM.
- Bnjmn22Mar 07, 2022Aspirant
Done. I was sent a beta firmware link by JeraldM but the Sharepoint link was not accessible to anyone outside the Microsoft Netgear domain/authentication. If the new beta firmware works I will keep this thread updated.
Thank you,
Benjamin
