GCCJay
Dec 20, 2021Aspirant
Nessus Professional Vulnerability scan kills internet connectivity through SXR80
Our setup: We have two completely separate, physically isolated networks. One is our corporate network with no wi-fi, and the second is a simple business grade cable-internet that we use solely to ...
RaghuHR
Dec 22, 2021NETGEAR Expert
Hi GCCJay
Could you please download the debug from https://<ip address of Orbi>/debug.htm
Send me link via PM to download.
Thanks,
Raghu
- GCCJayDec 22, 2021Aspirant
Hi Raghu,
The debug page won't allow me to save debug logs without first initiating a capture. Do I need to run the Nessus scan again and reproduce the issue while the router is capturing the debug logs?
- RaghuHRDec 22, 2021NETGEAR Expert
Yes start capture, recreate the issue and then save the debug logs.
Thanks,
Raghu
I started the capture and began the Nessus scan. Within 10 minutes the issue was reproduced. The problem now is that when I reproduce the issue, not only is the router completely non-functional from a networking standpoint, the Web UI is not responsive, either over wi-fi or ethernet. So I have no way to save the logs without power cycling the router. Is there a way for the logs to be preserved through a power cycle? Or some other way to get the logs after the router crashes?
I should also mention that the issue occurs no matter if the Nessus scanning laptop is connected to the router via wi-fi or ethernet.
Thanks for your assistance.
