GCCJay
Dec 20, 2021Aspirant
Nessus Professional Vulnerability scan kills internet connectivity through SXR80
Our setup: We have two completely separate, physically isolated networks. One is our corporate network with no wi-fi, and the second is a simple business grade cable-internet that we use solely to ...
GCCJay
Dec 22, 2021Aspirant
Hi Raghu,
The debug page won't allow me to save debug logs without first initiating a capture. Do I need to run the Nessus scan again and reproduce the issue while the router is capturing the debug logs?
RaghuHR
Dec 22, 2021NETGEAR Expert
Yes start capture, recreate the issue and then save the debug logs.
Thanks,
Raghu
- GCCJayDec 22, 2021Aspirant
I started the capture and began the Nessus scan. Within 10 minutes the issue was reproduced. The problem now is that when I reproduce the issue, not only is the router completely non-functional from a networking standpoint, the Web UI is not responsive, either over wi-fi or ethernet. So I have no way to save the logs without power cycling the router. Is there a way for the logs to be preserved through a power cycle? Or some other way to get the logs after the router crashes?
I should also mention that the issue occurs no matter if the Nessus scanning laptop is connected to the router via wi-fi or ethernet.
Thanks for your assistance.
