Beamur14's avatar
Beamur14
Netgear Orbi Pro SKX80 Alexa (Echo Show 5) Connection Issues
Hello,
I recently purchased the Netgear Orbi Pro SKX80 for my home network and have configured it to have 4 SSIDs (two internal / admin networks with 2 separate security profiles, 1 IoT network and the guest network). The SSID I'm trying to connect to is the Wireless 3 "IoT" network in the orbi admin interface using the deault Iot VLAN Profile. It is configured to use WPA-PSK [TKIP] + WPA2-PSK [AES] since the Echo Show 5 and a lot of my other devices do not support newer security options.
My Echo Show 5 device REFUSES to connect to the IoT network but can connnect without issue to the 2nd internal/admin network I have configured with WPA2-PSK [AES]. This is the only device that refuses to connect. I have an Echo Show 8 and an Echo Dot that connect to the IoT network without issue. Has anyone come across this? The error received on the device is "DHCP Error - Could not connect to internet". I have attempted to resolve this by suppling a DHCP reservation based on the device's MAC address and even configuring the device with a static IP by manually inputting the SSID on the Echo Show 5 and inputting the appropriate information.
Performing initial research "Fast Roaming" was disabled after manually being enabled as a troubleshooting step but that didn't help. I tried separating the SSIDs to 2.4GHz and 5GHz but that didn't help either. I have factory reset the device and that didn't help and as mentioned earlier I tried manually inputting the information for the network and providing a static IP and that hasn't helped.
Looking to see if anyone else has had this issue and has found a fix
  • Not to necro this thread but I want to provide closure in case anyone comes across this.
    Unfortunately I was unable to resolve this issue with my Orbi Pro. No matter what I tried I was unable to successfully get a stable wireless connection for the Echo Show 5 and a Ring Smart Lighting Bridge when directly connected to the Orbi Pro systems WiFi network.
    To resolve the issue I used an old Netgear R6400 lying around that I physcially connected to the Orbi Pro via ethernet in "AP" mode. It's connected to one of the Orbi Pro's LAN ports configured with the IoT VLAN. I then configured the R6400 to be in "AP" mode with a separate set of 2.4GHz and 5GHz SSIDs.
    After attaching the Echo Show 5 and Ring Smart Lighting Bridge to the R6400 everything has been functioning without issue for those two devices. They grab a DHCP IP from the Orbi system and they are succesfully restricted to the IoT VLAN.
    I would prefer to just use my Orbi system but this solution is working fine without issue for now.
  • Try resetting the Echo Show. Also change WPA-PSK [TKIP] + WPA2-PSK [AES] to WPA2-PSK [AES] only.
    • Beamur14's avatar
      Beamur14
ProSupport for Business
