LourensK
Feb 19, 2021Follower
Netgear orbi pro srk60
Which app can I use with the netgear orbi pro srk60?
I have downloaded the android app, but it doesn't work?
You have the insight app and the normal app (android)
Which for which system?
1 Reply
The Orbi App is for the consumer Orbi systems.
The Insight App can be used - with a different function set than the above - on the Orbi Pro and Orbi Pro WiFi 6 system.
