ry8s
Apr 30, 2024Aspirant
Netgear Orbi SXR30 4.3.4.200 Killed 1 Wifi Network?
Hey all, After the latest firmware update on my Netgear Orbi SXR30 Router and its 2 SXS30 satellite APs a month ago - my main wifi network has been basically disconnected. Tablets, laptops, Matter...
May 01, 2024Guru - Experienced User
So this happens will all other wireless VLANs disabled?
Did this happen on prior version of FW?
How was the FW on the system updated? Manually or automatic?
Has a factory reset and setup from scratch been performed since updating to check this problem?
- ry8sMay 03, 2024Aspirant
I have not tried disabling any other VLANs or other wireless networks - I will test that the next time the issue occurs. The issue disappeared a couple days ago, last time it took a couple weeks for it to come back, and then also resolved after a couple days.
This did not happen on any previous FW - except the issue did persist after downgrading to 4.3.3.106. All upgrades to 4.3.4.200 have been through me triggering it though the Netgear Insight iOS app.
I have not done a factory reset yet, that will likely be my next step if the issues comes back.
