Jan 29, 2022Guru - Experienced User
New - SXK80 Series Firmware Version v3.3.0.124 Released
Security Fixes:
Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Download Link:
https://kb.netgear.com/00...
phoenix10386
Jan 29, 2022Tutor
Thank you for fixing whatever security issues you fixed. I have installed this, and seems everything is stable so far.
I was using 3.3.0.122 and I encountered two peculiar issues:
1. Satellite would connect to the router and display a blue bar LED and it would go off after 3 minutes.
However, a few seconds later, the white LED would pulse, and go through the same motions as if the satellite rebooted. Factory reset did not solve this.
2. Using Wireless 2 for printer. I keep that SSID enabled but broadcast disabled. After a restart, the SSID is enabled and broadcast. I have to disable the broadcast all over again. Is this a bug?
If that is relevant, I have not enabled (ticked the checkbox) the VLAN profile on either Wireless 1 or 2. Is that why the second wireless disrespects my choices?
I will try this with the latest update. Also, kindly advise, is it recommended I factory reset after each update to iron out any issues or is that just a feel-good myth?
phoenix10386
Jan 29, 2022Tutor
I have set VLANs for both Wireless 1 and 2, separately, and still Wireless 2 is broadcast upon restart. Positively a bug, unless I am somehow mistaken.
- BruceGuoFeb 08, 2022NETGEAR Expert
Hi
Can you describe more to let us help you?
