Mar 06, 2022Guru - Experienced User
New - SXK80 Series Firmware Version v4.0.0.118 Released
New Features: 03/03/2022
Supports SXK30 and SXK80 compatibility, allowing you to set up an Orbi Pro WiFi mesh system using a combination of these devices. The SXS30 and SXS80 satellites can sync ...
phoenix10386
Mar 06, 2022Tutor
Enable Fast Roaming option is back! :heart:
Feels like a solid update so far, with general improvements across the board. For example, I was unable to see the open uPNP ports previously, now I can.
Meaningful improvements for everyone, such as, instead of "Insight: On/ Off" status, there is now a Management Mode status that says "Local web browser" or "Insight". If it says Insight, you can click it to visit the Insight portal directly. Much better, clearer!
- quagmire1Mar 07, 2022Luminary
Where is "Management Mode" located?
- phoenix10386Mar 12, 2022Tutor
It is located in the Router Information box under Advanced Home.
- quagmire1Mar 12, 2022Luminary
Ah - I needed to scroll to see it. Thank you!
