Mar 06, 2022Guru - Experienced User
New - SXK80 Series Firmware Version v4.0.0.118 Released
New Features: 03/03/2022
Supports SXK30 and SXK80 compatibility, allowing you to set up an Orbi Pro WiFi mesh system using a combination of these devices. The SXS30 and SXS80 satellites can sync ...
phoenix10386
Mar 06, 2022Tutor
Enable Fast Roaming option is back! :heart:
Feels like a solid update so far, with general improvements across the board. For example, I was unable to see the open uPNP ports previously, now I can.
Meaningful improvements for everyone, such as, instead of "Insight: On/ Off" status, there is now a Management Mode status that says "Local web browser" or "Insight". If it says Insight, you can click it to visit the Insight portal directly. Much better, clearer!
quagmire1
Mar 07, 2022Luminary
Where is "Management Mode" located?
- phoenix10386Mar 12, 2022Tutor
It is located in the Router Information box under Advanced Home.
- quagmire1Mar 12, 2022Luminary
Ah - I needed to scroll to see it. Thank you!
