FURRYe38's avatar
New - SXR30 / SXS30 Firmware Version 4.3.4.200 Released
Bug Fixes: 04/03/2024
  • Fixes an issue where the device that is connected on Ethernet to SXR30 or SXS30 does not come UP for approximately 30 seconds.
  • Fixed the delay in updating the Attached Device details in SXR30.
  • Fixed the accessibility of SXR30/SXS30 admin page using Chrome browser.
  • Fixes an issue where the user unable to access SXR30 when its LAN interface is assigned with 10.0.0.1 IP address.
Known Issues:
  • After updating the router firmware, existing WiFi clients might be steered to the router because the WiFi networks on the router come up faster than the WiFi networks on the satellite. The existing WiFi clients might notice slower throughput or a weaker signal.
    Workaround: Manually reconnect to the satellite, or roam to the area that is covered by the satellite.
  • WPA3-Enterprise might not work with an iPhone 11 that supports 802.11ax and that runs iOS 14 or a later iPhone model that runs iOS 14.
    Workaround: Do not use WPA3-Enterprise.
  • You can access the router web interface only over the default VLAN network.
    Workaround: Connect to a WiFi network that uses the default VLAN profile.
  • When an SXR80 router is connected to multiple SXS30 and SXS80 satellites, an SXS30 satellite might not be able to ping the SXR80 router, and the bar LED might light magenta. However, clients can still access the SXS30 satellite and the Internet.
    Workaround: Reboot the SXS30 satellite and the SXR80 router.
  • When an SXR80 router is connected to multiple SXS30 and SXS80 satellites, WiFi clients that connect to the Wireless 3 network with the VLAN feature enabled cannot access the Internet.
    Workaround: Reboot the SXR80 router or disable the VLAN feature on the Wireless 3 network.­­
Download Link:
https://www.netgear.com/support/product/sxk30#download
Firmware Update Instructions:
If the Orbi Pro is connected to the Insight cloud, perform a firmware update through the firmware schedule policy, or manually perform a firmware update using the Insight app or local browser interface.
To update the Orbi Pro firmware from router web interface, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click Documentation on the product page. We highly recommend updating the satellite firmware first, and then updating the router firmware.
After updating to the latest firmware, make sure to update your version of the NETGEAR Insight app for the best functionality and user experience.
This article applies to:
