Leia
Dec 26, 2019NETGEAR Employee Retired
New Firmware V2.5.0.108 for SRR60/SRS60/SRC60/RBS50Y(for Orbi Pro) Now Available!
New Features and Enhancements:
- Improves client identification by using Fing service and upgrading icons in the Attached Device page.
- Now supports WPA2-Enterprise.
- Adds PMF/802.11w support to enhance wireless security.
- Adds wireless 3 for IoT devices.
- Adds automatic configuration backup.
- Updates the https certificate.
- In Insight, "Allow employees to see each other and access my local network" is now enabled by default.
Bug Fixes:
- When the Orbi Pro is in AP mode, clients in wireless 2 can now access the Internet even when "Allow employees to see each other and access my local network" is selected.
- The Attached Device page now displays properly in the French language version of the local browser UI.
- Fixes a configuration provisioning problem when changing configuration from router mode to AP mode.
Known Issues:
- Wireless 3 is allowed in MAC ACL but the clients can get blocked after a while. Workaround: Do not use MAC ACL with wireless 3.
- RADIUS setting on the router can take effect on both 2.4Ghz and 5Ghz radio. The UI has a text error.
Download Links:
SRR60 - http://www.downloads.netgear.com/files/GDC/SRK60/SRR60-V2.5.0.108.zip
SRS60 - http://www.downloads.netgear.com/files/GDC/SRK60/SRS60-V2.5.0.108.zip
SRC60 - http://www.downloads.netgear.com/files/GDC/SRC60/SRC60-V2.5.0.108.zip
RBS50Y - http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y-V2.5.0.108.zip
Firmware Update Instructions:
If the Orbi Pro is connected to the Insight cloud, perform a firmware update through the firmware schedule policy, or manually perform a firmware update using the Insight app or local browser interface.
To update the Orbi Pro firmware from the local browser interface, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click Documentation on the product page. We highly recommend updating the satellite firmware first, and then updating the router firmware.
After updating to the latest firmware, make sure to update your version of the NETGEAR Insight app for the best functionality and user experience.
Additional Firmware Update Instructions for RBS50Y(for Orbi Pro):
The Orbi Outdoor (RBS50Y) uses different firmware versions depending on which wireless system you use. As of 2.3.5.22, RBS50Y detects whether the Orbi Router is an Orbi Pro system, and if so, automatically updates to Orbi Pro-compatible firmware.
If the firmware version is showing 0.0.0.0 on RBS50Y, the system is preparing to update to the Orbi Pro-compatible firmware.
mreruc We are in the process of releasing new firmware which will fix most of your issues in the first of week of February. That is our current ETA. We will reach you if there is any change.
Thank you for your feedback and patience.
Raghu
Hello Leia
Leia wrote:New Features and Enhancements:
We have complaints of insecure connection on using https://orbilogin.com ...
Is this a properly CA signed certificate or some self-signed crap?
- LeiaNETGEAR Employee Retired
schumaku wrote:
Hello Leia
It's self-signed certificate.
- VintnersApprentice
.Since the new firmware, no Apple devices can connect - any suggestions?
- MarchalAspirantNot all devices visible on app and internet based login
How is that possible, i’m able to connect And work with “offline” devices anyway..?!?
Last firmware update give more problems, remote management also not works for me anymore.
Hope there will be an update soon again, this one didn’t work for me- mrerucAspirant
When can we expect a Firmware Update?
Literally as the days go by every reported bug issue is starting to pop up. (connected clients issue, unable to remote login, orbi app won't remote login, and now users are receiving "Access Blocked" even though I have blocked no one)
I tried to roll back the firmware and I get 404 errors when I try it. This is beyond frustrating.
Luckily, Insight works to some degree, but I'm afraid I'll wake up and find that's blown up in my face also.
