atxtechguy11
Dec 08, 2023Aspirant
New Firmware V4.3.3.106 Tanks Orbi Wifi 6 Mini Pro Speeds
I have a SRX30 Orbi wifi6 Mini Pro with 2 satelittes. After upgrading to V4.3.3.106, the wifi speeds have absolutely cratered on the router. Speeds went from 400mb/s on my iphone 13 to 20mb. I've tr...
schumaku
Dec 13, 2023Guru - Experienced User
Something messed-up in the VLAN membership for a LAN, WiFi network, for employee and the default LAN 1? Why not using the default LAN 1 instead of the Employee LAN 2? From wally brain, the Employee VLAN is on VLAN 20 by default, the default LAN 1 on VLAN 1 ... somehow managed to merge these?
atxtechguy11
Dec 13, 2023Aspirant
Wireless 1 is supposed to be used for administration, wireless 2 for general use. This isn't related to VLANs and LAN IDs.
- schumakuDec 13, 2023Guru - Experienced User
All of the
defaultpreset networks have associations to different VLANs, intended Wireless 1 network usage is for administrative and general access - great for simple usability. The idea for having Wireless 2 (the so called Employee access) is to have a network (VLAN) to have the Employees off the admin environment.Afraid, you have not told us anything about the wired network and the possible association of the three LAN ports on the router and four LAN port on each satellite.
Let's challenge BruceGuo - he might have an idea how disabling Wireless 1 could have an impact on the Wireless 2 performance and throughput..
