atxtechguy11
Dec 08, 2023Aspirant
New Firmware V4.3.3.106 Tanks Orbi Wifi 6 Mini Pro Speeds
I have a SRX30 Orbi wifi6 Mini Pro with 2 satelittes. After upgrading to V4.3.3.106, the wifi speeds have absolutely cratered on the router. Speeds went from 400mb/s on my iphone 13 to 20mb. I've tr...
Dec 13, 2023Guru - Experienced User
So what happens if you use WiFi 1 instead of 2 for your main?
Still haven't let us know if you have this enabled or not on your SXR:
Possible NG changed the behavior on WiFi 2 and it's not a bug. You might get ahold of NG support and ask them about this.
Has a factory reset and setup from scratch been performed since last FW update to check this?
atxtechguy11
Dec 13, 2023Aspirant
I've always used Wireless 2 as the orbi advised Wireless 1 was for administration.
yes, UL-OFDMA is enabled. Yes I did a factory reset, that's how I fixed it the first time, because it re-enabled Wireless 1.
It's no longer an issue as I can just leave Wireless 1 enabled, but forever reason, the new firmware cap the downloads of Wireless 2 at 20mb when wireless 1 is disabled, either without SSID Bandwidth throttling enabled.
