DavidGo's avatar
DavidGo
NETGEAR Expert
Oct 05, 2021
New SRK60/SRC60/RBS50Y Firmware Version 2.7.0.122
SRK60
New Features:
  • Supports Business VPN service with Insight IM-6.3. This feature is available by subscription when the device is managed by NETGEAR Insight. (All models)
Bug Fixes:
  • Fixes intermittent connectivity issues with WAN related to daylight saving times under certain conditions. (All models)
  • Fixes the issue with backhaul stability when the triband mode is enabled on the satellite.  (SRR60/SRS60)
  • Fixes an issue where hardware acceleration sometimes caused crashes. (SRR60/SRS60)
  • Fixes an issue displaying internet speeds in the Orbi app. (SRR60/SRS60)
  • Fixes the missing attachment on the diagnostics email. (SRR60/SRS60)
  • Fixes automatic firmware upgrade when onboarding router to Insight. (SRR60/SRS60)
  • Fixes the issue where a device is dropped from the Attached Devices page if the name contains a special character. (SRR60/SRS60)
  • Fixes an issue when onboarding to Insight before performing basic Day0 setup.  (SRR60/SRS60)
  • Improves the stability of client information in an Insight-managed AP with 40+ clients. (SRR60/SRS60)
Known Issues:
  • After updating the router firmware, existing clients can be steered to the router because the wireless readiness in the router is faster than the wireless readiness in the satellite. (All models)
    Workaround: Connected clients might notice slower throughput or a weaker signal, which resolves when the user roams or reconnects.
Download Link:
SRR60: https://www.downloads.netgear.com/files/GDC/SRK60/SRR60-V2.7.0.122.zip
SRS60: https://www.downloads.netgear.com/files/GDC/SRK60/SRS60-V2.7.0.122.zip
SRC60: https://www.downloads.netgear.com/files/GDC/SRC60/SRC60-V2.7.0.122.zip
RBS50Y: https://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y-V2.7.0.122.zip
Firmware Update Instructions:
If the Orbi Pro is connected to the Insight cloud, perform a firmware update through the firmware schedule policy, or manually perform a firmware update using the Insight app or local browser interface.
To update the Orbi Pro firmware from the local browser interface, follow the instructions in your product’s user manual. The user manual is found by going to the NETGEAR Support page and entering the model number in the search box.
After updating to the latest firmware, make sure to update your version of the NETGEAR Insight app for the best functionality and user experience.
