chadonmac
Jan 09, 2021Initiate
Orbi firmware V2.6.0.108 no longer allows Orbi App connection
I let the Orbi insight app update my router and satelites to V2.6.0.108 and now i am unable to connect to my network through the local Orbi App. I have tried all troubleshooting steps(I could connec...
schumaku
Feb 08, 2021Guru - Experienced User
Tonytonytony wrote:
I bought the orbi pro in Jan 2020, there was no mention that I would lose the “Free” monitoring capabilities via the app. I hope you have a disclaimer in place for all new Orbi Pro purchases, your clients would probably appreciate to know that the “free” monitoring is only valid for a year.. then it will cost them $$$ onwards. Not sure any home users would be purchasing your Orbi Pros knowing they would need to fork over extra $$$ later on. I’m using this for home and definitely not happy about the extra $$$ needed to be able to use an app to view my connections..
When reviewing the Orbi Pro SRK60 - AC3000 Tri-band WiFi System Data Sheet D-SRK60-7Feb19 - so dated 07-FEB-2019 - there is no mention of the subject Orbi App ... just the Insight.
Tonytonytony
Feb 08, 2021Tutor
Never heard about the insight app. The recommended app was Netgear Orbi from the manual for installation.
