bouncyball
Nov 12, 2021Aspirant
Orbi Mini Pro SXK30 (SXR30+one SXS30) with WPA2 Enterprise setup
Hello everyone, I have successfully set up freeradius auth with SXK30 (firmware v110). But there is one annoyng thing. When wifi client tries to authenticate with router (SXR30) the process goe...
RaghuHR
Nov 12, 2021NETGEAR Expert
Hi bouncyball
Could you please send us the debug logs? both from router and satellite. We will investigate.
- bouncyballNov 12, 2021Aspirant
I forgot to mention that when I came across this issue I've been experimenting with "Wireless 3" settings while main "Wireless 1" has been set to WPA3 Personal (SAE) and been working good.
I kept experimenting and reconfigured "Wireless 1" to "WPA2 Enterprise" as well. After this, surprisingly, it worked with satelite authentication and when I checked "Wireless 3" it worked too! (?)
So now on every authentication change to router/satelite, router (not satelite) connects to radius server and I can clearly see in radius logs, that "Called-Station-Id" changes to router/satelite MACs accordingly.
Well, in order to not waste your time I'm not attaching Orbi debug logs here any more.
Thank you for your attention and such a quick response.
your answer was a hint that It should be working out of the box and kept me testing further.
The best regards
bb
