ColdFire3000
Jun 06, 2022Aspirant
Orbi Pro SXR30 SXS30 wired backhaul
I have a brand new Orbi setup and having nothing but issues with it. My setup is:
Downstairs
Virgin router->switch with SXR 30 plugged into it
Switch->cat5 cable through ceiling to middle floor
Middle floor
Cat5 from downstairs->Switch->Cat 5 to loft
Loft
Cat5 from middle floor->Switch-> SXS30
There is no direct cable from the downstairs to the loft, it goes downstairs->middle floor then another cable middle floor->loft.
There is a switch on the middle floor because I have various equipment on the middle floor which needs connecting. The same in the loft.
The reason for a new wifi setup is that we now have an office in the loft space which needs better wifi.
My issues:
1. I get good WiFi downstairs and on the middle floor. I get reasonable WiFi in the loft space... Until I plug in the SXS30 satellite in the loft space. My devices then connect to that and the throughput drops around 50%. You might say why bother using the satellite, but that's not really the point here... It should be working for wired backhaul, but...
2. I think that the satellite is not using the wired backhaul for some reason, but I am not sure why. I say think because I can't seem to see any clear way to identify if it is using wired or wireless backhaul!? Is there a way to check that I am missing?
If it is truly using wired then there is another issue...
I have tried plugging the satellite directly into the router, but the issue seems to remain. I had a long 10m cable and put the satellite in another room from the router, then put my WiFi devices in the 2nd room with the satellite, they connected to it and the performance was poor.
I tried calling NetGear support, but that was a complete waste of time unfortunately!
I am an IT engineer by trade and have plenty of experience of WiFi solutions, my gut told me not to get NetGear, but I thought I would give it a go as it seems to get good reviews, but I am really struggling with this. The main issue is the lack of information on the wired backhaul status, ie wired vs wireless. I am giving this another day or two and it's going back if I don't get any answers, will get Unifi or something else instead.
Thanks
- I didn't do anything differently in terms of config, except that I did it all using the web interface rather than the stupid app.
This time everything worked the way it was supposed to.
I've got all the cabling setup exactly the same way. Although in testing the wireless backhaul is actually working quite well, so might leave it wireless for easier locating.
As promised, the attached images show the satellite connected via wireless Vs wired backhaul between the router and the satellite. Note that the wireless part being lit up or not. I've not seen this information clearly shown with screenshots anywhere, only in the Orbi app, so hopefully it's helpful to someone!
The User Manual for the SXR30 system may hold information:
https://www.downloads.netgear.com/files/GDC/SXK30/SXK30_UM_EN.pdf
Page 29 explains how to access the web management using a web browser.
Page 154 shows how to access the Attached Devices display that will show how the satellites are connected to the router and which devices are connected to each unit.
It is not clear to me why there would be a switch between the Virgin router and the Orbi router.
The more common solution is to connect the Orbi directly to the ISP device and place any switches needed for that location behind the Orbi.
p.s. It's probably a good idea to identify the specific brand/model of switches in the network.
There can be problems with certain switches, especially when the switches support IGMP Snooping.
- ColdFire3000Aspirant
They are standard unmanaged Netgear GS108's. But as I said, I have the same issue without the switches involved, with the satellite directly connected to the main router.
Make sure the SXS are ethernet connected behind the SXR, not in parallel with the SXR at the switch.
The setup is as per diagram 3 in the link, but with an extra switch between the router and the SXS. But as I said, I have the same issue with a direct connection to the router it seems, so the switches are not relevant really.
Sorry, that was an oversight in the explanation.
It is actually
Downstairs
Virgin router->SXR 30->switch with->Cat5 cable through ceiling to middle floor
Middle floor
Loft
So the only/correct way to confirm a satellite is working via wired backhaul is that it shows in the 'wired' section of the attached devices section, is that right? That seems rather poor. There is a whole section of the app dedicated to satellites, but it doesn't mention it in there... 😞
I have read the manual several times and the diagrams. The setup is essentially diagram 3, but with an extra switch->switch in the middle. But as far as I can see that should work, it does with any other setup like this.
I found a post on here from someone saying that it only works if you have nothing else connected to the switches, but that seems wrong...
In any event, the switches can be ignored really. As I said, I can't seem to get it to work/confirm that it is working when I have just the satellite connected directly to the router. I did this with a 10m Cat5 cable, placed the satellite in another room with a thick wall between it and the main router. I then put WiFi devices in the 2nd room with the satellite. I confirmed they are connected to the satellite and are getting roughly 50% throughput! I unplug the satellite and they get around 90% throughput from the main router!
- ColdFire3000AspirantI might finally be getting somewhere. After a lot of messing I decided to reset the system and start from scratch. Initial testing with wired backhaul seems to be working, wireless backhaul is performing fine as well now.
I'm really not sure what was wrong with it before, but it seems a lot more hopeful this time!
I'm hoping to get some downtime tonight to switch things over and give it a real test...
Will also upload some screenshots for others which shows how to tell if the satellite is using wired or wireless backhaul.
