cpolizzi's avatar
cpolizzi
SXR30 and Verizon FIOS
I am trying to replace the CR100B Verizon Router with an SXR30 Router and 1 satellite.  I have reset the router to factory settings and it ended with a solid white light.  I connected to the router using same cabling from working system.  Reboot fiber optic modem and then power up SXR30.  I hard wire with my computer, go through the Netgear setup but end up with a Magenta light and no internet connection.  I haven't used this router in some time but it did work before.
SXR30 firmware is 4.3.4.200
Any insights would be appreciated.
  • I spent 2 hours in a chat with Verizon and they were no help whatsoever.  They would not answer a question as basic as, "Do you support 34d party routers in place of your own equipment?"
    However, I did finally find the attached document.  It appears that the ODN holds onto the IP address lease for their modem blocking attempts to replace their router.  By issuing a command to release the IP address on the Verizon router and immediately unplugging it, I could then install the SXR30 with no issues.
    Note that the document is from Verizon.  All they kept saying was they didn't recommend 3rd party devices as they had a bunch of value added features that they could not elaborate on.
    The Verizon solution was to replace the router with an older version (a CR1000A instead of CR1000B) and add 2 network extenders of their own.  The newer router my son already had would have to be hardwired to the extenders while the older one could work wirelessly.
ProSupport for Business
